PwnageTool for iPhone OS 3.1 [iPhone 3GS, iPod touch 2G]
Δημοσίευση 02/10/2009 - 22:34
Να υπενθυμίσουμε πως το Jailbreak δεν υποστηρίζει OTB (out of the box) iPhone 3GS δλδ συσκευές που αγοράστηκαν με την v3.1 προ-εγκατεστημένη...
Προσοχή:
The iPhone 3GS is now supported in PwnageTool 3.1.3, assuming the phone was pwned at 3.0 or 3.0.1 - PwnageTool does not support the 3GS out of the box. If your iPhone 3GS has 3.1 preinstalled and is not Pwned then there is no tested jailbreak solution at the moment.
The iPod 2G is now supported in PwnageTool 3.1.3, assuming the iPod 2G was pwned at 3.0 or 3.0.1 - PwnageTool does not support the iPod 2G with 3.1 software out of the box.
DETAILS:
1. GOLDEN RULE: If you are using a iPhone 3G or iPhone 3G(S) with ultrasn0w and rely on ultrasn0w to obtain cellular service then you should only update your device with an .ipsw that is made with the new PwnageTool. There are no second chances with this. You need to remember that PwnageTool will provide an upgrade path to newer versions of the iPhone software in the future.
2. Please read all parts of this post before downloading and using these tools.
3. Read items 1, 2 and 3 again and again.
4. At the bottom of this post are the bittorrent files for the 3.1 capable version of PwnageTool.
5. PwnageTool will work for the iPhone 3GS assuming you have already Pwned it at 3.0 or 3.0.1
6. PwnageTool will work for the iPod touch 2G assuming you have already Pwned it at 3.0 or 3.0.1
7. PwnageTool WILL work for Original iPhone (1st Generation), the iPhone 3G and iPhone 3G(S) and the iPod touch (1st Generation and 2nd Generation) but NOT the iPod touch 3rd generation.
8. For 3G and 3G(S) users who are Pwned, PwnageTool is your key to updating in the future, just remember to never install an update directly from Apple, always use an .ipsw that has been created with PwnageTool.
9. There is no Windows version of PwnageTool it is a Mac OS X tool only, we are not developing a Windows version of PwnageTool.
PwnageTool 3.1.3 download link: Torrent - Rapidshare
Oδηγός: http://www.isepsis.c...emid=65&lang=el
Ποιοί μπορούν να ακολουθήσουν τον παρακάτω οδηγό:
- Χρήστες iPhone 3GS με v3.0 ή v3.0.1 αγορασμένο από Ελλάδα (δλδ unlocked) που έχουν ήδη χρησιμοποιήσει το RedSn0w και έχουν jailbroken συσκευές.
- Χρήστες iPhone 3GS που έχουν αναβαθμίσει στην v3.1 ΑΛΛΑ προνόησαν και κράτησαν το απαραίτητο ECID file
Οι χρήστες που ανήκουν στην 2η κατηγορία θα πρέπει να πρώτα κάνουν downgrade στην v3.0 ή v3.0.1 πριν ακολουθήσουν τον οδηγό.
Ποιοί ΔΕΝ μπορούν να ακολουθήσουν τον παρακάτω οδηγό:
- Χρήστες iPhone 3GS που αγόρασαν την συσκευή με την v3.1 προ-εγκατεστημένη
- Χρήστες iPhone 3GS οι οποίοι αναβάθμισαν στην v3.1 χωρίς να κρατήσουν το απαραίτητο ECID file
Αρχικά θα χρειαστούμε να κατεβάσουμε τα παρακάτω:
• PwnageTool 3.1.3
• iPhone2,1_3.1_7C144_Restore.ipsw (iPhone 3GS)
• iTunes 9
Αρχικά, εγκαθιστούμε το PwnageTool (Mac only) και ανοίγουμε την εφαρμογή.
- Επιλέξτε το Expert Mode από το menu του PwnageTool, επιλέξτε το iPhone 3GS σας και πατήστε 'επόμενο' ->
- Το PwnageTool θα ψάξει για το 3.1 ipsw
- Επιλέξτε το firmware, πατήστε 'επόμενο' -> και θα δείτε 6 επιλογές...
- General
1. Δεν τσεκάρετε το Activate εφόσον έχετε iPhone 3GS αγορασμένο από Ελλάδα.
2. Aυξάνετε το μέγεθος του partition root στα 700MB.
Επιλέξτε επόμενο ->
- BootNeuter
Τα checkboxes θα είναι μη επιλέξιμα, οπότε προχωράτε στο επόμενο menu.
- Cydia
Aπό αυτό το menu μπορείτε να επιλέξετε τα packages του Cydia τα οποία επιθυμείτε και να τα περάσετε κατευθείαν στο custom .ipsw που δημιουργείτε με το PwnageTool ώστε να μην χρειαστεί να τα εγκαταστήσετε χειροκίνητα από το Cydia.
Επιλέξτε download packages και με διπλό κλικ κατεβάστε το package που επιθυμείτε π.χ το OpenSSH
Από το menu Select packages τικάρετε τα packages που επιθυμείτε να περάσετε μέσα στο custom .ipsw και πατήτε 'επόμενο' ->
- Custom Packages
Επιλέξτε το Cydia
- Custom Logos
Μπορείτε να αλλάξετε τα Boot logo και Recovery logo... Καλύτερα να αφήσετε τα original.
- Build
Είστε έτοιμοι να δημιουργήσετε το custom .ipsw. Πατήστε το build και η διαδικασία θα αρχίσει...
- Θα ζητηθεί να επιλέξετε το που θα σώσετε το αρχείο και θα αρχίσει η διαδικασία δημιουργίας του custom ipsw.
- Θα σας ζητηθεί να εισάγετε το password σας. Στη συνέχεια πατήστε Enter.
- Το PwnageTool θα δημιουργήσει την custom firmware και θα σας ζητήσει να θέσετε το iPhone σε Recovery mode:
1. Συνδέστε το καλώδιο USB ΜΟΝΟ στο Mac
2. Κρατήστε το power button πατημένο μέχρι να εμφανιστεί το “slide to power off” και κλείστε την συσκευή.
3. Κρατώντας πατημένο το Home button στο iPhone συνδέστε το με το USB.
4. Συνεχίστε να κρατάτε το Home button και θα δείτε να εμφανίζεται το Apple logo και στην συνέχεια το “Connect to iTunes”. Αφήστε το Home button
- Το iTunes θα εντοπίσει το iPhone σε Recovery mode. Επιλέξτε OK.
- Το iTunes θα ξεκινήσει το Restore του iPhone με το custom ipsw
Extra Tip: Όταν συνδέσετε το iPhone στο iTunes επιλέξτε το 'Set up as a new iPhone'. Μπορεί να χάσετε τα backup σας (άλλωστε με ένα sync θα περάσετε και πάλι contacts, calendar, photos κτλπ) ΑΛΛΑ θα έχετε ένα 'καθαρό λειτουργικό' και θα γλυτώσετε από πολλά προβλήματα τα οποία προκαλεί το 'Restore from a previous backup'
Δημοσίευση 02/10/2009 - 23:04
Και τα δύο...
Δεν θέλω να αμφισβητήσω αυτό που λες (δεν με συμφέρει) αλλά στα βήματα-οδηγό που γράφει η dev team δεν αναφέρει κάπου για locked τηλέφωνα (ή δεν το πρόσεξα καλά
Οπότε με 3GS locked από Αμερική, που αυτή τη στιγμή δουλεύει σε 3.0(unlocked-jailbraked φυσικά) we are good to go ;
Δημοσίευση 02/10/2009 - 23:10
Μπορεί να έχεις δίκιο και πολύ καλά έκανες που με αμφισβήτησες! Η αλήθεια είναι πως δεν έχω ακούσει αν το 3GS είναι κλειδωμένο στην Αμερική!Δεν θέλω να αμφισβητήσω αυτό που λες (δεν με συμφέρει) αλλά στα βήματα-οδηγό που γράφει η dev team δεν αναφέρει κάπου για locked τηλέφωνα (ή δεν το πρόσεξα καλά
. Μόνο για factory unlocked.
Δημοσίευση 02/10/2009 - 23:12
Είναι κλειδωμένα κανονικά και με το νόμο
Δημοσίευση 02/10/2009 - 23:14
τι εννοείς για εμάς? Το παληκάρι είπε πως το κινητό το πήρε από Αμερική...Είναι κλειδωμένα κανονικά και με το νόμο
Απλά όπως ήδη είπα ενώ χάρηκα στην αρχή με την είδηση, δεν βλέπω να λένε κάτι για εμάς...
Δημοσίευση 02/10/2009 - 23:16
Πάντως αυτο που εγω είπα είναι ότι έχω 3G με OS 3.0 unlocked και jailbroken. όχι 3GS.
Οπότε ισχύει για μένα?
Εννοώ γενικά για όλους εμάς με locked 3GS. Που δεν αναγράφουν κάτι για εμάς
Δημοσίευση 02/10/2009 - 23:26
Δημοσίευση 02/10/2009 - 23:31
To θέμα είναι ότι ΔΕΝ μου ζήτησε καν να συνδέσω το τηλέφωνο όσο το έκανε, οπότε δεν έχει καμία σχέση το εκάστοτε τηλέφωνο με το IPSW.
Με άλλα λόγια, όποιος δημιουργήσει ένα IPSW, μπορεί να το μοιραστεί με τους άλλους!
Το μόνο που κάνει συγκεκριμένο το τηλέφωνο, είναι ότι έχοντας αλλάξει το hosts file ώστε να κάνει point στον server του Saurik, εκείνη μόνο την ώραπου κάνετε restore το custom firware από το iTunes έχει σημασία να έχετε το ECID SHSH "on file".
Κοινώς, σε καμια ώρα θα έχω ανεβάσει το custom firmware, το κατεβάζουν όσοι έχουν Windows, αλλάζουν το hosts file αν δεν το έχουν κάνει ήδη, και κάνουν shift+restore το firwmare από το iTunes.
Το PwnageTool χρειάζεται μόνο για την δημιουργία του custom firmware ( Βέβαια, αφού είναι έτσι, απορώ γιατί δεν έφτιαξαν απλώς ένα IPSW και να το ανεβάσουν κάπου για download, αντί να διανέμουν το PwnageTool)...
Διορθώστε με όποιος ξέρει κάτι παραπάνω...
Δημοσίευση 02/10/2009 - 23:32
Δημοσίευση 02/10/2009 - 23:34
Κάποια φάση που ρωτάει το πρόγραμμα κάτι για contract, itunes και activation τι πατάμε?
Αν έχεις κινητό από ελλάδα, δηλαδή ξεκλείδωτο, πατάς Ναι
Δημοσίευση 02/10/2009 - 23:37
Δημοσίευση 02/10/2009 - 23:39
Δημοσίευση 02/10/2009 - 23:42
Και πως αλλαζουμε το hosts file?Παιδιά, ψυχραιμία...Απ ότι βλέπω, το PwnageTool φτιάχνει ένα IPSW χρησιμοποιώντας το original , που μετά φυσικά το φτιάχνει custom.
