* * - - - 3 ψήφοι
Διαθέσιμα τα PwnageTool, redsn0w και ultrasn0w για το untethered jailbreak και unlock του iOS 5.1.1 από την Dev-Team
190 μηνύματα σε αυτό το θέμα
Δημοσίευση 04/06/2012 - 17:31
H Dev-Team έδωσε στην κυκλοφορία πριν λίγο τις νέες εκδόσεις των PwnageTool, redsn0w και CInject που υποστηρίζουν untethered jailbreak στο iOS 5.1.1.
Συγκεκριμένα:
RedSn0w
redsn0w allows owners of A4+earlier devices to install rocky-racoon two different ways:
● backup/restore method similar to Absinthe and cinject
● its traditional limera1n-based ramdisk install. If you have a lot of media on your A4 device (music, movies, TV shows, etc), then the ramdisk method is preferrred because it avoids any possibility of later problems related to syncing to iCloud (including Photo Stream and Music Match). The ramdisk method is not available for A5 devices or later because limera1n can't be used. If you'd like to use redsn0w's ramdisk method, just be sure to put the A4 device in DFU or Recovery mode before starting redsn0w (otherwise it will immediately start to use the backup/restore method).
We've also added a new redsn0w feature specifically for those who got in on the SAM unlock: you can now include your SAM tickets as part of your initial ramdisk jailbreak of iPhone4 or earlier, or alternatively you can upload your SAM tickets to any device after its been jailbroken. redsn0w accepts either the individual SAM activation ticket plist file, or the entire zip file created by redsn0w's "Backup" button. As usual, redsn0w continues to cover all of its previous jailbreaks and untethers (so redsn0w-0.9.12b1 covers everything from 5.1.1 all the way back to 4.1).
PwnageTool
PwnageTool also avoids any possible sync issues, but again it applies only to A4+earlier devices. If you unlock your iPhone with ultrasn0w or a commercial method, you must use PwnageTool to avoid updating your baseband otherwise you'll lose the unlock. PwnageTool will also jailbreak+untether the AppleTV2,1 5.0_2B206f (unless you customize the IPSW further, you'll have just basic SSH access to the device).
Μπορείτε να κατεβάσετε τις εκδόσεις αυτές εδώ:
-PwnageTool
-Redsn0w (Mac)
-Redsn0w (Windows)
-CInject
Επίσης, διαθέσιμη είναι και η νέα έκδοση του ultrasn0w 1.2.7 που υποστηρίζει το ξεκλείδωμα μερικών παλιότερων baseband στο iOS 5.1.1. Οι συσκευές που υποστηρίζονται είναι οι iPhone 3G/3GS με 04.26.08, 05.11.07, 05.12.01, 05.13.04, και 06.15.00 και iPhone 4 με 01.59.00. Το ultrasn0w μπορεί να εγκατασταθεί στη συσκευή σας εφόσον έχει γίνει jailbreak σε αυτή.
#2   tttsakalos
tttsakalos
  • 384 μηνύματα
  • GameCenter:tttsakalos
Δημοσίευση 04/06/2012 - 17:35
μπραβο στα παιδια.ειναι πολι καλυτερα για τους περισοτερους. :D :D :D
#3   giabri
giabri
  • 3.131 μηνύματα
Δημοσίευση 04/06/2012 - 17:36
ποια η διαφορα με το absinthe?
RF forever
#4   dim18
dim18
  • 126 μηνύματα
Δημοσίευση 04/06/2012 - 17:37
Αλλάζει κάτι στο jb;Ουσιαστικά ενσωμάτωσαν το Absinthe στο redsnow.
Κερδίζουμε κάτι;;Μήπως είναι πιο εύκολο με redsnow το jb;
#5   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
  • GameCenter:tgousopoulos
Δημοσίευση 04/06/2012 - 17:38
δεν νομιζω να ειναι πιο ευκολο.
το absinthe δεν χρειαζεται ουτε dfu.
#6   dim18
dim18
  • 126 μηνύματα
Δημοσίευση 04/06/2012 - 17:39
Και εγώ έτσι νομίζω.
Κάνουν ακριβώς το ίδιο όμως;
#7   caution
caution
  • 134 μηνύματα
Δημοσίευση 04/06/2012 - 17:40
^ Λογικά τα ίδια exploits θα εκμεταλλεύεται με πανομοιότυπο κώδικα, άρα θα εκπλαγώ αν υπάρχουν διαφορές ;)
#8   nikosgnr
  • 113.594 μηνύματα
Δημοσίευση 04/06/2012 - 17:42
Aναμενόμενο.. Και άργησε κιόλας..
RedSn0w.. Εγγύηση.
#9   dim18
dim18
  • 126 μηνύματα
Δημοσίευση 04/06/2012 - 17:43
RedSn0w.. Εγγύηση.
Δηλαδή καλύτερα με redsnow παρά με Absinthe;;
#10   nikosgnr
  • 113.594 μηνύματα
Δημοσίευση 04/06/2012 - 17:44
Προσωπικά το προτιμώ.
Πάντα με RedSn0w.
#11   MarkKnopfler
MarkKnopfler
  • 16.726 μηνύματα
  • Twitter:@Fmiggas
  • GameCenter:markknopfler
Δημοσίευση 04/06/2012 - 17:45
Το ίδιο είναι παιδιά απλά το redsnow είναι πιο παλιό tool με διορθωμενα bugs και περισσότερες επιλογές.Τα ίδια exploit χρησιμοποιούν και άρα το ίδιο Jailbreak,εφόσον γίνει με οποίο και να γίνει το ίδιο θα είναι..
#12   jimlos
jimlos
  • 857 μηνύματα
  • GameCenter:jimlost
Δημοσίευση 04/06/2012 - 17:50
απλα το jb με το redsnow εχει μια διαδικασια,που στο absinthe ειναι πιο ευκολη........
και επειδη ειχα κανει jb στην 5.0.1 με το redsnow μαλλον και τωρα με αυτο θα janakanv
Τελευταία επεξεργασία από: jimlos, 04/06/2012 - 17:52
#13   xxxxxx
  • 9.340 μηνύματα
Δημοσίευση 04/06/2012 - 17:52
εγω αυτους δεν τους πολυπηγαινω γιατι παντα εδιναν τα exploits στην apple μολις εκαναν jb
#14   nikosgnr
  • 113.594 μηνύματα
Δημοσίευση 04/06/2012 - 18:02
Nα σημειώσουμε πως με το 0.9.12b1 δε χρειάζεται DFU για Α5.
Τελευταία επεξεργασία από: nikosgnr, 04/06/2012 - 18:08
#15   caution
caution
  • 134 μηνύματα
Δημοσίευση 04/06/2012 - 18:04
Ούτως ή άλλως, από την στιγμή που το jb είναι public, δύο-τρεις καλοί μηχανικοί @ Cupertino μπορούν να "πάρουν" με reverse τεχνικές τα exploits, αν πραγματικά το θέλουν ;)
Χρήστες που διαβάζουν αυτό το θέμα: 21
0 μέλη, 21 επισκέπτες, 0 ανώνυμοι χρήστες
