* - - - - 1 ψήφοι
[TIP] Μπορώ να κάνω downgrade από την iOS 6? (Blob-o-riffic)
179 μηνύματα σε αυτό το θέμα
#1   nsxbass
nsxbass
  • 9.378 μηνύματα
  • Twitter:@n1ckstrat
  • GameCenter:nsxbass
Δημοσίευση 19/09/2012 - 21:54
Πριν λίγο κυκλοφόρησε η έκδοση 6 του iOS.
Άμεσα η dev-team έσπευσε να μας ενημερώσει για το ότι αναβαθμίζοντας στην iOS 6 ίσως να μην μπορούμε να γυρίσουμε πίσω στην 5.1.1 ή σε κάποια παλιότερη.
Αυτό εξαρτάται από τη συσκευή που έχουμε στα χέρια μας και από το αν έχουμε κρατημένα τα shsh blobs.
Αναλυτικά ή ανακοίνωση:
"Today marks the public release of iOS6! For those devices capable of running 6.0, the 5.1.1 SHSH blob signing window will soon close, so it’s very important that you backup your 5.1.1 blobs now while you still can. We advise you do it for every device you have (see tutorial sites like iClarified if you don’t know the process).
A few months back we released a redsn0w feature that lets you downgrade A5+ devices from 5.1.1 to anything lower (if you had saved blobs). Unfortunately once the 5.1.1 window closes, redsn0w’s 5.x downgrade feature will no longer work. Most A5+ users will not be able to downgrade. So if you’re an A5+ owner up at 6.0 when the 5.1.1 window closes, you’ll be stuck there without a jailbreak for now.
We’re happy to report there are some serious deficiences in the 5.x restore process that are permanently exploitable. They’ll never be fixable by Apple because they’re all self-contained in the 5.x IPSWs. Here’s the breakdown:
  • A4 devices and 3GS will always be downgradable (and jailbreakable) with saved blobs due to limera1n. The tethered iOS6 jailbreak for those devices (and untethered for old-bootrom 3GS) will be out when Cydia and other important pieces are all working properly.
  • iPad2 owners who have both 4.x blobs and 5.x blobs will always be able to downgrade to those versions, even once you come up to 6.0 and the 5.1.1 window closes (don’t do that yet though!). You need both 4.x and 5.x blobs to qualify for the 5.x downgrade even though you only wish to downgrade to 5.x (you need only your 4.x blobs to downgrade to 4.x)
  • iPad3, i4S (and iPad2 owners who don’t satisfy #2) will always be able to RE-restore the current 5.x OS that’s already on their device. So if you’re at 5.1.1 when the window closes (and you’ve saved your blobs), you’ll always be able to RE-restore to 5.1.1 again. This makes the 5.1.1 jailbreak a lot less fragile — you don’t have to worry about messing up your install with funky extensions or getting into a boot loop, because you can always RE-restore from 5.1.1 to 5.1.1 again (or from 5.0.1 to 5.0.1 again, etc). But once you fall off the 5.x train by restoring to 6.x, you’ll be stuck there until the next jailbreak.
Please be aware that RE-restores and iPad2 downgraded devices will always end up with the latest baseband (not the one that came with that firmware). So don’t go near any of this if your unlock depends on the baseband version.
All of these features will be released shortly in a new version of redsn0w. In the meantime please be sure you have your 5.1.1 blobs and stay at 5.1.1. Happy iOS6 day!
Update #1: For a refresher on why saved blobs are not as powerful as they used to be, please see our Blob Monster post (the scenarios described above are possible only due to mistakes made by Apple, but those mistakes are being cleaned up with each new firmware)."
Ανάλογα λοιπόν, με τη συσκευή μας, υπάρχουν 3 περιπτώσεις:
1. Οι κάτοχοι συσκευών με Α4 επεξεργαστές και οι κάτοχοι 3GS θα μπορούν κανονικά να κάνουν downgrade με τη χρήση των shsh και μάλιστα θα έχουν και tethered jailbreak (untethered για τα old-bootrom 3GS) λόγω του limera1n.
2. Οι κάτοχοι iPad 2 που έχουν shsh blobs από παλιότερη 4.Χ έκδοση ΚΑΙ από 5.Χ έκδοση θα μπορούν ΓΙΑ ΠΑΝΤΑ να κάνουν downgrade στις εκδόσεις αυτές, ακόμα και αν αναβαθμίσουν στην 6.0. ΠΡΟΣΟΧΗ! Για να ισχύει αυτό θα πρέπει να έχετε τα shsh blobs από την έκδοση 4.Χ ΚΑΙ από την έκδοση 5.Χ για να κάνετε downgrade στην έκδοση 5.Χ (αν θέλετε να γυρίσετε σε 4.Χ χρειάζεστε μόνο blobs της 4.Χ).
3. Οι κάτοχοι 4S, iPad 3 (και οι κάτοχοι του ipad 2 που δεν ικανοποιούν το 2) θα μπορούν για πάντα να κάνουν restore στην 5.Χ που βρίσκεται αυτή τη στιγμή στη συσκευή τους. Οπότε, αν είστε στην 5.1.1, όταν συτή θα σταματήσει να υπογράφεται, εφόσον έχετε τα shsh της 5.1.1 θα μπορείτε για πάντα να κάνετε restore στην ίδια την 5.1.1. Οπότε μπορείτε να αισθάνεστε ασφαλείς, μιας και ακόμα και αν κάτι πάει στραβά και χρειαστεί να κάνετε restore, μπορείτε να περάσετε την 5.1.1 και να κάνετε πάλι jailbreak. ΠΡΟΣΟΧΗ! Αν περάσετε την 6.0, δεν θα μπορείτε να γυρίσετε μέχρι να βγει το επόμενο jailbreak!
ΠΡΟΣΟΧΗ!! Όσοι ενδιαφέρεστε για UNLOCK μείνετε μακρυά από οποιαδήποτε διαδικασία! Ακόμα και τα downgrade καταλήγουν με τη baseband της τελευταίας έκδοσης και όχι αυτής του firmware που περνάτε!
Όλα τα παραπάνω σύντομα θα είναι εφικτά μέσω νέας έκδοσης του redsn0w. Μέχρι τότε βεβαιωθείτε ότι έχετε σωσμένα τα shsh blobs για την 5.1.1!!!
Τελευταία επεξεργασία από: nsxbass, 19/09/2012 - 21:56
#2   Researcher
Researcher
  • 3.615 μηνύματα
Δημοσίευση 19/09/2012 - 21:56
Γιατί υπάρχει jb για 4s και ipad 3 ή το αναφέρει για κάποια στιγμή στο μέλλον...
#3   nsxbass
nsxbass
  • 9.378 μηνύματα
Δημοσίευση 19/09/2012 - 21:58
Δε μιλάει κάπου για jb στην 6.0.
Στην 5.1.1 ναι υπάρχει jb και στο 4S και στο iPad 3!
#4   MarkKnopfler
MarkKnopfler
  • 16.726 μηνύματα
  • Twitter:@Fmiggas
  • GameCenter:markknopfler
Λέει ότι αν δεν πας σε 6.0 τότε μπορείς να κάνεις στην 5.1.1 restore.
Αν πας στην 6.0 τότε πρέπει να βγει νέο JB(συνεπώς και νέο Redsnow) για να κάνεις restore στην 5.1.1
#5   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
  • GameCenter:tgousopoulos
Δημοσίευση 19/09/2012 - 22:07
Ωραια νεα αυτα.Να μας φυγει και το αγχος.
#6   nsxbass
nsxbass
  • 9.378 μηνύματα
Δημοσίευση 19/09/2012 - 22:15
Νομίζω ότι ήταν πολύ καλή κίνηση το ότι ξεκαθάρισαν το τοπίο τόσο άμεσα.
Γιατί ήταν αναμενόμενο να υπάρξουν περίπου 500000000000 ερωτήσεις επί του θέματος...
#7   Maldino
Maldino
  • 42 μηνύματα
Δημοσίευση 19/09/2012 - 22:58
Συγνωμη αν ειναι χαζη η ερωτηση. Μπερδευτηκα.
Κρατησα SHSH 5.1.1 στο iPad 3 μεσω TinyU. Τωρα ειμαι σε φαση update στο iOS 6. Υπαρχει επιστροφη για μενα στην 5.1.1 και JB που με καιει?
Ευχαριστω εκ των προτερων.
#8   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
Δημοσίευση 19/09/2012 - 22:59
Οπως βλεπεις στο πρωτο ποστ δεν μπορεις να γυρισεις αν περασεις την ios 6.
#9   nsxbass
nsxbass
  • 9.378 μηνύματα
Δημοσίευση 19/09/2012 - 23:01
Όχι.
Γιατί μπερδεύτηκες?
Το λέει καθαρά.
Έχεις iPad 3, ανήκεις στην περίπτωση 3!
Εφόσον πατήσεις στην 6.0 ΔΕΝ υπάρχει περίπτωση επιστροφής στην 5.1.1, τουλάχιστον μέχρι να βγει jb για την 6.0! Άρα αποχαιρετάς το jb για λίγο (ή και πολύ) καιρό.
Και ακόμα και τότε, δεν είναι σίγουρο αν θα γίνεται downgrade, αλλά δε θα σε νοιάζει κιόλας!
Τελευταία επεξεργασία από: nsxbass, 19/09/2012 - 23:02
#10   Maldino
Maldino
  • 42 μηνύματα
Δημοσίευση 19/09/2012 - 23:04
Καλως ευχαριστω. Τι να κανουμε... υπομονη!
#11   RedTiby
RedTiby
  • 78 μηνύματα
έχω το 3gs , είχα untethered jb στην 5.1.1! επειδή δεν τα πάω καλά με shsh και ιστορίες, δεν έκανα κάποια ένεργεια απλά restore - update στην 6!
μπορώ να κάνω jb σε tethered με το redsnow με κάποιον τρόπο?και αν ναι τι επιπτώσεις θα έχει αυτή η κίνηση?
Ευχαριστώ
#12   MarkKnopfler
MarkKnopfler
  • 16.726 μηνύματα
  • Twitter:@Fmiggas
Δημοσίευση 19/09/2012 - 23:05
Μήπως δεν έχει κατεβάσει ακόμα το update και το σώσει; Έχει αρχίσει η διαδικασία στο ipad?
Είναι το ipad προσπελάσιμο ή έχει βγάλει καμμιά μπάρα;
#13   Maldino
Maldino
  • 42 μηνύματα
Δημοσίευση 19/09/2012 - 23:10
Προσπελασιμο ειναι αλλα το θεμα ειναι οτι ειμαι πολυ περιεργος με οτι καινουργιο βγαινει.
Εχω 20 λεπτα να το ακυρωσω. Μεσω iTunes το κατεβαζω.
#14   DooMDiveR
DooMDiveR
  • 2.313 μηνύματα
  • Twitter:@Doomdiver
  • GameCenter:DooMDiveR
Δημοσίευση 20/09/2012 - 22:38
Παιδια να ξεκαθαρισουμε οτι οσο ακομα (λιγες ωρες προφανως) υπογραφει την 5.1.1 η apple ανεξαρτητου συσκευης μπορειτε να πατε ακομα πισω...! για τυχον παρεξηγησεις
#15   red71
red71
  • 709 μηνύματα
Δημοσίευση 21/09/2012 - 10:19
iphone 4 MD128GB γινετε downgrade σε 5.1.1???
