Cydia TSS Center
62 μηνύματα σε αυτό το θέμα
#1   xristos99
xristos99
  • 170 μηνύματα
Δημοσίευση 09/04/2013 - 11:42
Μπηκα πριν λιγο στο Cydia και μου εμφανιζει αυτο το μηνυμα πανω πανω, με πρασινα γραμματα (θεση που προηγουμενως υπηρχαν τα SHSH)
"See TSS Center (below) to request iOS SHSH"
O Saurik, εχει γραψει και ενα αρθρο στην κατηγορια TSS Center που εξηγει τι συμβαινει. Ριξτε του μια ματια, γιατι ξεκαθαριζει καποια σημεια.
(Ζητω συγγνωμη απο τους mods αν εχει ηδη δημιουργηθει παρομοιο θεμα και ας προχωρησουν στη διαγραφη αυτου αν υπαρχει)
#2   nikosgnr
  • 113.590 μηνύματα
Δημοσίευση 09/04/2013 - 11:50
Ουσιαστικά είναι το τέλος των SHSH, τουλάχιστον μέσα απο το Cydia.
Ο Saurik λέει αυτό που ήδη λίγο πολύ γνωρίζαμε. Είναι άχρηστα.
At this point, I think I have described everything I need in order to explain the current situation: all of the APTickets Cydia itself requested from Apple for iOS 6 are useless. The word "useless" is important, as it is not accurate to use the word "corrupt": the data that was uploaded was not lost or damaged, and in fact all of the tickets that were stored verified per the algorithm from MuscleNerd.
Instead, the requests being made via Cydia to collect SHSH information for iOS 6 did not result in useful tickets. This is because, in order to better emulate the requests Apple had been making when I first started the service, I filter the manifests I send to Apple to only include information about files that had the partial digests I discussed earlier, as only files that have partial digests are relevant for SHSH.
However, the APTicket signs complete digests, not partial digests, and so even descriptions of files that do not have partial digests need to be sent to TSS to get a complete ticket. What really should therefore be used as a filter is "files with digest information at all", not just those that have partial digests (there is never a partial digest without a full digest), effectively finding all "real" files.
The result is that the APTickets that were downloaded and saved by Cydia itself are not sufficient to boot a device. However, tickets that were downloaded or otherwise obtained by tools such as redsn0w, iFaith, or TinyUmbrella, will work fine. If those tickets are uploaded to Cydia and then downloaded back, they also will continue to work: it is only tickets downloaded by Cydia clients themselves that were affected.
Ολόκληρο το άρθρο εδώ
#3   xristos99
xristos99
  • 170 μηνύματα
Δημοσίευση 09/04/2013 - 11:51
Εδω και το αρθρο που ανεφερα: http://www.saurik.com/id/15
#4   xristos99
xristos99
  • 170 μηνύματα
Δημοσίευση 09/04/2013 - 11:54
Με προλαβες Νίκο :D
#5   Tr3LaRaS
Tr3LaRaS
  • 1.189 μηνύματα
Δημοσίευση 09/04/2013 - 12:31
και πως θα τα κραταμε ?
#6   nikosgnr
  • 113.590 μηνύματα
Δημοσίευση 09/04/2013 - 12:33
Μόνο αν τα είχες σώσει με Tiny.
#7   iStar
iStar
  • 3.419 μηνύματα
Δημοσίευση 09/04/2013 - 12:36
Τώρα δηλαδή δεν σώζονται?
#8   Tr3LaRaS
Tr3LaRaS
  • 1.189 μηνύματα
Δημοσίευση 09/04/2013 - 12:39
δε τα ειχα σωσει,τωρα δε μπορω ?
#9   nikosgnr
  • 113.590 μηνύματα
Δημοσίευση 09/04/2013 - 12:58
Aν τα είχες στο Cydia μπορείς τικάροντας απο Advanced το Request From Cydia να τα σώσεις.
Ως προς τη χρησιμότητα τους, δε ξέρω..
Διαφορετικά όχι.
Τελευταία επεξεργασία από: nikosgnr, 09/04/2013 - 12:59
#10   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
  • GameCenter:tgousopoulos
Δημοσίευση 09/04/2013 - 13:00
Διαφορετικά όχι.
Ναι αλλα για τα shsh του ios 6.x.x λεει οτι κατι δεν εχει γινει σωστα οποτε ειναι αχρηστα.
Οποτε αν κατεβουν με το tiny με τικαρισμενο το request shsh from cydia θα ειναι οκ?
#11   azaleea
azaleea
  • 6.766 μηνύματα
Δημοσίευση 09/04/2013 - 13:20
Γιατι δεν τα παιρνεις κατευθειαν με iFaith ;
#12   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
Δημοσίευση 09/04/2013 - 13:21
Αφου δεν υπογραφονται παρα μονο η 6.1.3.
Τελευταία επεξεργασία από: tgousopoulos, 09/04/2013 - 13:21
#13   nikosgnr
  • 113.590 μηνύματα
Δημοσίευση 09/04/2013 - 13:25
Αν τα είχες στο Cydia, και τικάρεις το Request θα στα σώσει απο Tiny.
Απο 'κει και πέρα για χρησιμοποίηση τους, άγνωστο. Μιας και δε σώνει APTicket.
Θα έχουμε νέα έκδοση RedSn0w. Ίσως για τα SHSH.
#14   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
Δημοσίευση 09/04/2013 - 13:27
Αρα ειτε τα εχουμε σωσει με tiny η με redsn0w η ifaith η τα "πηραμε" απο το cydia ειναι ακριβως το ιδιο?
#15   mpatakis
mpatakis
  • 2.389 μηνύματα
Δημοσίευση 09/04/2013 - 13:30
θα χρησημευσουν τα SHSH στο μελλον τελικα ή οχι?
