Το γνωστο μας Audiko.net μετακομισε και στο App Store, μονο για iPhone
Μπορειτε να το βρειτε απο εδω iTunes link ή απ ευθειας απο την συσκευη σας (δωρεαν)
MEET AUDIKO ON YOUR IPHONE
Our really light and easy to use application will allow you the next:
- Create custom ringtones from the music stored on your iPhone.
- Cut the precise section of the track you want to set as your ringtone
Audiko is a famous community that allows users to exchange ringtones and create their own ringtones based on music tracks, videos and other sounds. Ringtone creation takes only seconds, and you don’t need to have special skills or use special tools.
- Interface improvements have been made for the best experience in ringtone creation.
- Performance and stability improvements.
- Minor bug fixes.
