Τα iPhone 6 και iPhone 6 Plus σε σύγκριση με ανταγωνιστικά μοντέλα Android
154 μηνύματα σε αυτό το θέμα
Δημοσίευση 23/09/2014 - 09:20
Τα νέα iPhone 6 και iPhone 6 Plus φαίνεται πως κερδίζουν τα περισσότερα ανταγωνιστικά μοντέλα Android σε επιδόσεις της CPU αλλά και στην διάρκεια της μπαταρίας, σύμφωνα με σειρά μετρήσεων (benchmarks) που διενήργησε το AnandTech, η εγκυρότερη ίσως ιστοσελίδα για hardware-reviews.
In in GPU benchmarks, we generally see a pretty solid lead over the competition for the iPhone 6/A8. It's seems quite clear that there is a significant impact to GPU performance in the iPhone 6 Plus due to the 2208x1242 resolution that all content is rendered at. It seems that this is necessary though, as the rendering system for iOS cannot easily adapt to arbitrary resolutions and display sizes.
There are a few interesting observations here, as a great deal of the scaling is above what one would expect from the minor frequency bump when comparing A7 and A8. In SunSpider, we see about a 13% increase in performance that can't be explained by frequency increases alone.
For Kraken, this change is around 7.5%, and we see a similar trend across the board for the rest of these tests. This points towards a relatively similar underlying architecture, although it's still too early to tell how much changes between the A7 and A8 CPU architectures.
Τέλος, όσον αφορά την διάρκεια χρήσης της μπαταρίας το iPhone 6 ξεπερνάει τα περισσότερα ανταγωνιστικά μοντέλα Android, ενώ το iPhone 6 Plus βρίσκει από πάνω του μόνο το Huawei Ascend Mate 2:
As with all of our battery life tests, we standardize on 200 nits and ensure that our workload in the web browsing test has a reasonable amount of time in all power states of an SoC.
As one can see, it seems that Apple has managed to do something quite incredible with battery life. Normally an 1810 mAh battery with 3.82V nominal voltage would be quite a poor performer, but the iPhone 6 is a step above just about every other Android smartphone on the market. The iPhone 6 Plus also has a strong showing, although not quite delivering outrageous levels of battery life the way the Ascend Mate 2 does.
#2   valsamis
valsamis
  • 2.579 μηνύματα
Δημοσίευση 23/09/2014 - 09:30
μα αφου τα εχουμε πει, το iphone εχει specs 2012!!! και ενα μονο gb ram!
#3   ntnskrds
ntnskrds
  • 2.334 μηνύματα
  • GameCenter:ntnskrds
Δημοσίευση 23/09/2014 - 09:31
Και μετα απο αυτο το post ολα τα φανδροιδ που σερνονται στο forum εβαλαν αγγελια για τα Nexus και ψαχνουν να βρουν το μυστηριωδες 'NVIDIA SΗIELD Tablet' ..  :P
#4   valsamis
valsamis
  • 2.579 μηνύματα
Δημοσίευση 23/09/2014 - 09:34
χαχαχαχαχαχαχ
#5   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
  • GameCenter:tgousopoulos
Δημοσίευση 23/09/2014 - 09:35
Xaxaxa καλο!
#6   Velkus
Velkus
  • 5.457 μηνύματα
  • Twitter:@SpyVeProductions
  • GameCenter:Velinikus
Δημοσίευση 23/09/2014 - 09:46
Εγώ ξέρω πως ο Βασίλης άναψε φωτιές.. :P
Αυτό το θέμα θέλει ποπ κορν!!  :lol:  :D
@CaLi@
#7   kinezaki
kinezaki
  • 190 μηνύματα
  • Tablet:iPad mini Retina +4G
Δημοσίευση 23/09/2014 - 09:52
εβαλα το gfx να τρεξει στο 5ς μου.... ειλικρινα το γονατιζει.........
#8   Gfb3
Gfb3
  • 474 μηνύματα
  • Tablet:iPad mini +4G
Δημοσίευση 23/09/2014 - 10:02
Καλύτερη μπαταρία το iphone 5 από το note 3 σε browsing? Επειδή τα είχα και τα δύο δεν νομίζω... Κατά τα άλλα πολύ εντυπωσιακά τα νούμερα από τα νέα iphone
#9   johny69
johny69
  • 14 μηνύματα
Δημοσίευση 23/09/2014 - 10:03
Κρίμα που δεν υπάρχει και το OnePlus One στα benches  :ph34r:  :laugh:  :laugh:  :laugh:
#10   Sakis
Sakis
  • 114 μηνύματα
Δημοσίευση 23/09/2014 - 10:31
Πολλά τα ερωτήματα για το συγκεκριμένο test και την εγκυρότητα του , και ξεκινώ με κάποιες πρώτες απορίες…
Το Samsung Galaxy note 3 γιατί δεν εμφανίζεται σε όλα τα γραφήματα???
Η σχέση τιμής απόδοσης προφανώς και ούτε αυτή μας απασχολεί , τα περισσότερα μοντέλα του test αυτή την στιγμή στην αγορά έχουν κατά μέσο όρο μισή τιμή από αυτή του iphone….
Το  Xaomi είναι αυτή την στιγμή 2ο σε πωλησεις στην Κίνα, μετά από τη  Samsung και πάνω από την Apple, δεν θα έπρεπε να εμφανίζεται και αυτό, η ντράπηκαν να το βάλουν ? (το Mi4 κυκλοφόρησε τον Αύγουστο και έχει μίση τιμή σε σχέση με τα νέα iPhone)
Αν είχα το χρόνο μπορεί να έγραφα βιβλίο αλλά θα κούραζε…
#11   ntnskrds
ntnskrds
  • 2.334 μηνύματα
Δημοσίευση 23/09/2014 - 10:35
Δεν χρειαζεται ουτε να κουραζεσαι ουτε να κουραζεις ... Αυτο το ξέρεις ??
#12   Sakis
Sakis
  • 114 μηνύματα
Δημοσίευση 23/09/2014 - 10:45
Δηλαδή το παραπάνω συγκριτικό "τεστ" ήταν το εισιτήριο του για να πάει να δουλέψει στην Apple ? Αυτό μου λες ? Αν ναι, να προσθέσω και άλλα “” στην λέξη test...
#13   valsamis
valsamis
  • 2.579 μηνύματα
Δημοσίευση 23/09/2014 - 10:53
αυτο παντος που με το ζορι το iphone να μην εχει καλα specs δεν το καταλαβαινω.,.. δηλαδη σαν κανει εντυπωση οτι εχουν τρομερα ατομα στην αππλε να δουλευουν στο hw? και να βγαζουν καλα αποτελεσματα...
#14   ntnskrds
ntnskrds
  • 2.334 μηνύματα
Οχι δεν λεω αυτο ... Λεω οτι εδω και ενα μηνα ο Anand Shimpi ειναι στην μισθοδοσια της Apple. Το AnandTech το τρεχει ο πρωην συνεργατης του .
Αλλα θα ξαναπηγαινες εκει με ελαφρια καρδια για εγκυρα και απροκαταληπτα hardware reviews η μηπως θα 'σουν λιγο πιο καχυποπτος ??
#15   Strategos
Strategos
  • 36 μηνύματα
Δημοσίευση 23/09/2014 - 11:04
Μόνο αυτό ...
AnandTech founder Anand Shimpi retires from journalism to join Apple
επίσης το να κάνεις σύγκριση onscreen με κινητά που έχουν χαμηλότερη ανάλυση είναι γελοίο μιας και το 5s τα έχει όλα!!
Τελευταία επεξεργασία από: Strategos, 23/09/2014 - 11:05
