Simple Mode:
Simple Mode does a simple one click process. You simply browse for your IPSW, and it will begin to build! If you select an iPhone IPSW then, sn0wbreeze will ask you if you on an Official Carrier. Answering that question will determine if you are needed to Hacktivate your Device, and fix YouTube + Push.
Expert Mode:
[GENERAL]
- Hacktivation (Activates you phone if you are not on a official carrier.)
- Add sn0wbreeze iPhone App, which keeps you up to date with all the latest news on sn0wbreeze, including upcoming releases, or new releases!
- Root Partition Size (For cydia applications, default size is 750 MB, Max is 7000MB[6.8GB])
[UNLOCKS]
- This will allow you to use any GSM Carrier that is not permitted by your Carrier.
- Select Blacksn0w for the iPhone 3G/3GS on 5.11.07.
- Select Bootneuter for the iPhone 2G.
[INSTALLERS]
- Cydia is always Installed.
- You have the option to install Rock aside Cydia.
[CUSTOM APPS]
- Install Cydia Applications/debs into the IPSW
- Custom Applications (From Big Boss, ZoTTD, Saurik, or Your own PC!) (Search Through the Repo via a Simple Search!)
[CUSTOM BOOTLOGOS]
- Replace the Apple Logo (On Boot)/Recovery Logo (In Recovery Mode) with your own Image!
- Boot Logos (Must be 320 x 480, Be less than 100KB in size, and have at least one transparent Pixel)
We are planning on releasing sn0wbreeze by the end of NEXT week! So Be Prepared!
**Reminder: sn0wbreeze Does Not Support any Tethered Devices!!!**
~iH8sn0w
iH8sn0w on twitter
iH8snow Forum
Official Sn0wbreeze website
Τελευταία επεξεργασία από: iPodTouchPro, 02/01/2010 - 02:15
