* * * - - 2 ψήφοι
MusicTransport: Νέο Cydia tweak από τον Ηλία Λιμναίο
12 μηνύματα σε αυτό το θέμα
Δημοσίευση 24/08/2015 - 09:14
Νέο tweak από τον Ηλία Λιμναίο, έρχεται σύντομα στο Cydia.
Το όνομα του, MusicTransport και αυτό που κάνει είναι να μεταφέρει μουσική, ηχογραφήσεις και ηχητικά εφέ μέσα στην κλήση (υποστηρίζει τηλεφωνικές κλήσεις αλλά και κλήσεις από Facetime ,Viber ,WhatsApp, Facebook Messenger, Skype, Tango και LINE), παράλληλα με τη φωνή του χρήστη.
MusicTransport-elias-limneos-cydia-tweak
MusicTransport-cydia-tweak-elias-limneos
Ακολουθεί η επίσημη λίστα των χαρακτηριστικών του tweak:
A new era, mixing audio with your voice in calls, has just arrived!
Transmit songs or sound effects in a call, mixed with your own voice! Other party thinks these sounds actually come from the place you are at the moment!
Ever wanted to call someone and have them listen to a song you like from your Music Library, over the phone?
Or dedicate a song to someone without being limited by the poor quality of placing your phone over a speaker?
Or sing a song or karaoke to someone over the phone, while they are listening to the song in full call quality along with your voice, fully mixed?
Or call someone and have them listen to a recorded Voice Memo you've made?
Or use a Voice Memo you have recorded as ambient sound effect, to have the one you're calling thinking you are in a different place at that moment?
Or make someone think you're in a different place, by adding sound effects or loud music in the background as they listen to you on the phone?
Ever wanted to call your boss and tell them you're stuck in traffic, having them hear all the traffic jam sounds in the background along with your voice, while you're still getting up, at home?
MusicTransport lets you do all the above and more!
With MusicTransport you can transmit any song from your music library (or even sound effects that you have synced) or any Voice Memo that you have recorded to the other caller, while they are also listening to your own voice, mixed with the background music/audio!
- Fully Mixed transmitted audio with your own voice, with no interruption at all.
- Song Selection from your Music Library. Unlimited sounds option, since you can broadcast any type of audio, songs, sound effects or ambient sounds that you have synced.
- Voice Memo Selection from your native Voice Memos app. You can even record your own ambient sounds and transmit them to make others think you are somewhere else. Or simply play them a recording you've made.
- Real-Time Volume Control to customise how loudly the other party hears the audio being transmitted. You can even use this to pretend you are approaching or moving away from a noisy place.
- Playback Controls to start, pause or position the audio being transmitted in real time.
- Local Audio Preview to hear what is being transmitted on your own headset, so you can sing along with the song or simply add more to the audio being transmitted!
- Seamless Repeat Mode to loop the song or sound effect being transmitted without interruption!
- Real-Time Scrubbing allows you to move the transmitted audio to any time frame instantly.
- Real-Time Switching of songs or recordings allows you to switch songs anytime and make a whole music broadcast over a phone call!
You can use MusicTransport in Telephony, Facetime ,Viber ,WhatsApp, Facebook Messenger, Skype, Tango or LINE calls!
Fully compatible with AudioRecorder and CallBar as well.
Works on iPhone 4S up to iPhone 6 / 6 Plus and on iPad 2 and above.
On an iPhone 4S, in order for the audio to be transmitted in a telephony call, you need to switch to speakerphone
Τιμή: $2.99 - Διαθέσιμο σύντομα.
#2   W3rtY88
W3rtY88
  • 2.979 μηνύματα
Δημοσίευση 24/08/2015 - 12:33
Και από update ? του Αγίου .... Ανήμερα
#3   tgousopoulos
tgousopoulos
  • 21.642 μηνύματα
  • GameCenter:tgousopoulos
Δημοσίευση 24/08/2015 - 12:38
Τον αδικεις. Ηταν οντως μια εποχη ειδικα με το CallBar που μας εβγαλε τη πιστη αλλα εχει στρωσει.
Και εχει για μενα 2 απομτα κορυφαια tweaks. CallBar,BioProtect.
#4   gismo301278
gismo301278
  • 5.413 μηνύματα
  • Twitter:@Fstavrou
  • GameCenter:gismo301278
Δημοσίευση 24/08/2015 - 12:49
Ο ανθρωπος ειναι φοβερος ξερει πολυ καλα τι κανει κι ειναι σωστος σε αυτα που κανει εχει κανει πολυ καλες δουλειες!!!ολοι εχουμε το callerid greece στο τηλεφωνο μας
Rafael Nadal
#5   thanosdk
thanosdk
  • 1.095 μηνύματα
Δημοσίευση 24/08/2015 - 13:28
Φοβερο το tweak, πολυ καλη δουλεια!! Αναμενουμε!
Τελευταία επεξεργασία από: thanosdk, 24/08/2015 - 13:28
#6   AthanGt
AthanGt
  • 120 μηνύματα
Δημοσίευση 24/08/2015 - 14:49
Οντως, πολυ καλο tweak !!!
Τελευταία επεξεργασία από: AthanGt, 24/08/2015 - 14:50
#7   AthanGt
AthanGt
  • 120 μηνύματα
Δημοσίευση 24/08/2015 - 14:50
Θα συμφωνησω οτι οντως κανει πολλη καλη δουλεια ο Ηλιας, κι εχω αγορασει κι εγω αρκετα tweaks του, αλλα με το smart tap που σε 6 και 6plus ειναι προβληματικο, κανενα update. :-(
Tο εχω δοκιμασει σε 3 συσκευες (δυο 6ρια κι ενα plus) κι ενω ειναι τοσο βολικη εφαρμογη, καταπινει τη μπαταρια για πλακα, αφου οτι ρυθμιση και να εχω δοκιμασει, η συσκευη εμφανιζει τον ιδιο χρονο χρησης με αναμονης. Δλδ 10 ωρες αναμονη πχ, 10 ωρες και η χρηση κι ας μην εχω αναψει καν την οθονη. Σε αντιθεση με το 5s της γυναικας μου που δουλευει αψογα.
#8   daskalakispavlos
daskalakispavlos
  • 3.430 μηνύματα
  • GameCenter:daskalakisp
Δημοσίευση 24/08/2015 - 16:14
Αν αυτός που σε καλεί ειναι καταχωρημένους ειναι σωτήριο.....με διαφορά μαζί με κανά δυο αλλα tweak ο λόγος να κανεις jailbreak.....
Knowledge Is Power
#9   W3rtY88
W3rtY88
  • 2.979 μηνύματα
Δημοσίευση 24/08/2015 - 17:52
Δεν είπα ότι δεν ειναι τρομερός dev και τον σέβομαι απεριόριστα για την δουλειά του αλλά εχει ένα θέμα με τα update
#10   ifrit
ifrit
  • 1.238 μηνύματα
  • Twitter:@ifritakos
  • GameCenter:ifrit
Δημοσίευση 25/08/2015 - 15:12
Αν ήταν και συνεπής θα ήταν απ' τους κορυφαίους devs. Παραμένει βέβαια εντυπωσιακός φυσικά.
#11   iPhoneHellas
Δημοσίευση 25/08/2015 - 16:46
Μόλις κυκλοφόρησε στο repo του BigBoss
#12   Goldstamos
Goldstamos
  • 82 μηνύματα
Δημοσίευση 26/08/2015 - 19:33
Πολύ ωραία τα tweak που φτιάχνει ,με της όποιες δυσλειτουργιες, και την ανύπαρκτη υποστηρίξει, και τα αναπάντητα μηνύματα.
#13   omorfonios
omorfonios
  • 1.647 μηνύματα
Δημοσίευση 26/08/2015 - 19:50
από τα καλύτερα tweak παιδιά...! μετά το Voice changer έχω ρίξει τρελα γέλια και με αυτό...! βάζω μια ηχογράφηση την ώρα που μιλάω στο τηλέφωνο και όλη νομίζουνε ότι μιλάνε αλλα άτομα από μέσα...! δοκιμάστε να βάλετε ηχους ενοχλητικούς όπως ηχους τηλεφώνου/modem και ότι άλλη ιδέα σκεφτείτε...! θα σπάσετε πολύ πλακα με τους φίλους σας...! ;)
