iDongle: Standalone Tethered Boot for 3.1.2 devices (iPhone 3GS, iPod Touch 2G/3G)
58 μηνύματα σε αυτό το θέμα
Δημοσίευση 10/03/2010 - 11:27
Το iDongle είναι η hardware λύση στο πρόβλημα του tethered boot για όσους έχουν Jailbroken συσκευή (iPhone 3GS, iPod Touch 2G/3G) με το νέο bootrom!
http://www.youtube.com/watch?v=0BK_FCXcyrk
Πως λειτουργεί;
1. Power-on your jailbreaked device
2. On iTunes logo, plug iDongle
3. Wait for leds to end flashing
4. Unplug iDongle or wait for boot
iDongle FAQ
What is it ?
This is a standalone piece of hardware able to boot your jailbreaked device (a.k.a “tethered boot”), and optionnally to jailbreak and hacktivate it if not already done.
Why do I need this ?
If your jailbreaked device is stuck into “recovery mode” (i.e Connect-to-iTunes logo) each time you restart or reboot your device, then it may be usefull for you =)
I want one !
From now, I only have a dozen of (working) prototype. I need to raise some minimal funds to start manufacturing them in quantities, to lower the price as much as possible for the community. You can help by buying me a prototype at good price, or simply donate as pre-order :)
How do I know if my device is concerned ?
Any iPhone 3GS made after week 40 (2009). The week number is usually the 4th and 5th digit of the serial number. iPod Touch 2G whose serial number begins with “MC” are concerned or any iPod Touch 3G.
Which device is supported ?
From now, iPhone 3GS and iPodTouch 2G/3G are supported, all with OS 3.1 / 3.1.1 / 3.1.2 only, but the later is recommended.
Will you support OS 3.1.3 ?
Maybe, or not. iDongle can be easily updated through USB. If jailbreak is available, I’ll try and post a free update.
Does it provide unlock ?
Not directly. Look for Geohot’s “sn0w” or Dev Team’s “ultrasn0w” package on Cydia.
Περισσότερες πληροφορίες μπορείτε να βρείτε στο myboyfriendisageek.com
#2   Slumber
Slumber
  • 198 μηνύματα
Δημοσίευση 10/03/2010 - 11:48
Promising (αν δεν αποδειχτει και αυτο fake or something).
Αλλα προσωπικα, αν ειχα 200 euros για να παρω κατι τετοιο, θα προτιμουσα να αγοραζα 10-20 official apps και θα ειχα ξεμπερδεψει (ξαναλεω...προσωπικα ^^)
#3   djibril13
djibril13
  • 963 μηνύματα
Δημοσίευση 10/03/2010 - 11:54
και ο geohot το ειχε προτεινει στην ψηφοφορια που ειχε κανει κατι μηνες πριν...απ'οτι φαινεται γι'αυτο δεν ασχολουνται με το untethered για να τα αρπαξουν χοντρα απο "λυσεις" τυπου idongle! >:( >:(
Τελευταία επεξεργασία από: djibril13, 10/03/2010 - 11:55
#4   Ultralord
Ultralord
  • 953 μηνύματα
  • Twitter:@levasval
  • GameCenter:val lev
Δημοσίευση 10/03/2010 - 12:23
δηλαδή με αυτό το κάνεις μία φορά? δηλαδή αν κλίσεις και το ανοίξεις πάλι θα θέλει πάλι idongle?
#5   DINFUN
DINFUN
  • 16.182 μηνύματα
Δημοσίευση 10/03/2010 - 12:29
Έχω την εντύπωση πως θα θέλει κάθε φορά.. Ηbootrom αναγνωρίζει πως εχουν επέμβει στην συσκευή..
#6   Slumber
Slumber
  • 198 μηνύματα
Δημοσίευση 10/03/2010 - 12:36
Και εγω ετσι καταλαβα. Καθε φορα θα θελει.
Απλα αντι να ψαχνεις να βρεις pc να τρεξεις το blackrain θα ψαχνεις περιπτερο για 9volt μπαταρια.
Σιγουρα πιο ευκολο, αλλα σιγουρα θα εξαρτηθει απο την τιμη.
Αν θελει donations 600$ για καμια 10αρια prototypes, ε τοτε η τιμη του stande θα ειναι τσιμπημενη.
Σορρυ για το παραπανω post μου με το "200αρι", παρεξηγησα το donation bar ::)
#7   Ultralord
Ultralord
  • 953 μηνύματα
  • Twitter:@levasval
Δημοσίευση 10/03/2010 - 13:22
κανά παλικάρι ηλεκτρονικός δεν υπάρχει να κάνει modification ένα flashaki να τρέχει στο connect το blackrain να σωθούμε? :P
#8   tryf
tryf
  • 480 μηνύματα
  • GameCenter:tryf3
Δημοσίευση 10/03/2010 - 15:04
Πολυ ωρα κανει ρε παιδια. Στο Pc σε πεντε δευτερα γινεται. Κατα την ταπεινη μου γνωμη δεν πολυσυμφερει.
#9   JimIceman
JimIceman
  • 16 μηνύματα
Δημοσίευση 10/03/2010 - 15:20
Ενδιαφέρον θα ήταν μόνο αν γινόταν μια κι έξω... να μας φύγει τουλάχιστον ο φόβος μην κλείσει κάπου που δεν μπορούμε να κανουμε τίποτα...αφου το θέλει κάθε φόρα δεν νομίζω να πολυαξίζει...
#10   rally170hp
rally170hp
  • 1.175 μηνύματα
  • GameCenter:Rally170hp
Δημοσίευση 10/03/2010 - 15:43
Τι λένε! Παντως έχω συνηθίσει να έχω το λάπτοπ μαζί μου όταν πάω κάπου μακριά,φορτιστι στο αμάξι έχω οπότε μια χαρά. Εδώ κ τρίς μήνες άντε να μου έχει σβήσει 3 φορές μόνο σιγά ´
#11   idomeneas
idomeneas
  • 612 μηνύματα
Δημοσίευση 10/03/2010 - 16:53
Ναι τώρα θα πω σ'ένα φίλο μου να σου φτιάξει 5-6 να έχεις :P
Θα δούμε την τιμή αν δεν είναι πολλά λεεί!!! 8)
Από το να μείνεις κιόλας χωρίς τηλέφωνο και να σε γελάνε οι άλλοι
και να λένε σου έλα αλέκο.. καλύτερα να έχεις ένα τέτοιο στην τσέπη!!! :D
Αν βέβαια βγει κάποιο πιο μόνιμο θα ήταν καλύτερα!!
#12   georgeVLS
georgeVLS
  • 137 μηνύματα
Δημοσίευση 10/03/2010 - 22:40
Πλάκα κάνουν έτσι? Οτι θα κυκλοφορησει αυτο το μαραφετι??
#13   Neopas
Neopas
  • 1.133 μηνύματα
Δημοσίευση 11/03/2010 - 00:12
Πολυ καλο. Μαγκια!
Σε κατι τετοια φαινεται ποιος εχει μυαλο που δουλευει.
Οταν μπορει να λυσει ενα προβλημα εστω και με πλαγιο τροπο.
Τωρα η τιμη.. αλλο καπελο.
Ο καθενας κοστολογει τον χρονο και τον κοπο του οσο θεωρει σωστο, με οτι συνεπειες εχει αυτο.
#14   ktzaf
ktzaf
    iPH Honored Elite member
  • 1.283 μηνύματα
Δημοσίευση 11/03/2010 - 11:39
Λίγο προσοχή θέλει ρε παιδιά, δεν είναι ανάγκη να πετάτε τα λεφτά σας. Αν και πρέπει να ομολογήσω πως αν το παλικάρι είναι legit πάνω από ένα €50 με μεταφορικά δεν θα σας φύγει. Από αυτά που περιγράφει, η τιμή των υλικών είναι €22 και σκέφτεται να το πουλάει στα €30. Ήδη τα donations για την αρχική παραγγελία υλικών για 50 κομμάτια είναι στο 82%, θα ξέρουμε σύντομα τι παίζει, αν και οι χρόνοι παράδοσης δεν φαντάζουν μικροί (30 λεπτά χρειάζεται να συναρμολογήσει ένα idongle).
#15   AlfistaFotis
AlfistaFotis
  • 25 μηνύματα
  • Twitter:@alfistafotis
Δημοσίευση 11/03/2010 - 13:01
Το μια κι έξω δεν υπάρχει περίπτωση να γίνει. Μόνο άμα βρουν άλλη τρύπα... <_<
