Cider: Manage Cydia from your PC
15 μηνύματα σε αυτό το θέμα
Δημοσίευση 13/03/2009 - 02:10
Το Cider είναι μία νέα εφαρμογή μέσω της οποίας μπορείτε να χειριστείτε τα packages του Cydia από το PC σας:
Download and upload to your iPhone packages from multiple Cydia repositories.
Posted Image
Adding a new repository:
Posted Image
1. To add a new source, open the first tab (Sources). Then enter the full address of the repository.
2. Click the "Add".
3. After that, the repository will appear in the list.
4. Click the "Update Selected Resources." Cider will automatically update the repository.
Downloading the package:
Posted Image
1. Go to the second tab (package). Here is a list of packages.
2. Select your package. The information and description will appear in the right window
3. To download the package, check its box and then click "Download the selected packages. Cider will automatically download it.
Installing packages on the iPhone:
Posted Image
[img][/img]
1st way:
You can copy the package into the cache Cydia on iPhone and sync sources. Then, open Cydia and install the required package of regular way. Cydia will not download this package - because it will already be in its cache. You can even turn off the Edge before launching Cydia, and it will save not only the traffic you spend on the download package, but also on the procedure for updating the sources.
2nd way (the easiest):
Copy the package to a folder on the device avtoustanovki Cydia. After restarting your iPhone, the package will be installed automatically.
3rd way (most difficult):
Copy the package into the device, start the terminal and install the package using dpkg tools
Click on the "Sync" can manage a set of sources and packages that are in the cache program, as well as in the device.
Download Cider
Σημείωση: H εφαρμογή είναι στα Ρώσικα. Η Αγγλική μετάφραση αναμένεται σύντομα...
Source
#2   LeroyR
LeroyR
  • 38 μηνύματα
Δημοσίευση 13/03/2009 - 07:09
Αυτο ειναι φοβερο νεο αλλα για οσους δεν ξερουν ρωσικα θα περιμενουμε ελπιζω λιγο  :P
#3   kargas
kargas
  • 148 μηνύματα
Δημοσίευση 13/03/2009 - 10:50
1. όταν του βάζω τα sοurcesδεν μου βγάζει τα πακέτα του
2. όταν το κλείνω και το ανοίγω πάλι δεν χάνονται όλα
#4   iPodTouchPro
iPodTouchPro
  • 3.187 μηνύματα
Δημοσίευση 13/03/2009 - 11:33
....δηλαδη κατι παρομοιο με αυτο που θα βγαλει η RipDev.Επιτελους!!
#5   asxetos32
asxetos32
  • 36 μηνύματα
  • Tablet:iPad+3G
  • GameCenter:asxetos32
Δημοσίευση 13/03/2009 - 11:56
Δηλαδή με αυτό μπορούμε να πάρουμε και Backup τις εφαρμογές μας;
#6   sepsis
Δημοσίευση 13/03/2009 - 12:20
Δεν είναι τόσο καλό ακόμα. Δεν δέχεται όλα τα sources αλλά μόνο ορισμένα (τα οποία θα τα βρείτε στο φόρουμ τους)
Η εφαρμογή εμένα στα Αγγλικά είναι, μενού και όλα
για backup δεν νομίζω. Απλώς για εγκατάσταση από το PC είναι
#7   iPodTouchPro
iPodTouchPro
  • 3.187 μηνύματα
Δημοσίευση 13/03/2009 - 12:46
εμενα παντως δεν ειναι στα ρωσικα αλλα στα αγγλικα και το κατεβασα απο το link που δωσατε στο πρωτο post.
#8   LeroyR
LeroyR
  • 38 μηνύματα
Δημοσίευση 13/03/2009 - 14:38
Για να δω
#9   stargazer
stargazer
  • 18 μηνύματα
Δημοσίευση 13/03/2009 - 18:07
Το πρόγραμμα είναι μια ευγενική χορηγια του Hansi του Andre του Μarcus και του Frederik(Blind Guardian)  :P
Thanx παιδιά Somewhere Far Beyond rulezz...:D
Posted Image
#10   ToroLoco
ToroLoco
    Member
  • 139 μηνύματα
Δημοσίευση 16/03/2009 - 13:09
Λοιπόν αυτό που πρόσεξα είναι ότι κατέβασα κάποια apps τα έβαλα στο cache του Cydia, αλλά 1ον το repo που πέρασα από το cider δεν υπήρχε στο iphone έπρεπε να το περάσω ξανά. Μετά όταν πάτησα να εγκαταστήσω μια εφαρμογή από αυτές που είχα κατεβάσει πέρασε και τις υπόλοιπες.
#11   panosru
panosru
  • 87 μηνύματα
Δημοσίευση 02/04/2009 - 17:50
Παιδιά ξέρουμε αν θα βγει κάτι παρόμοιο και για Mac? Πάλι καλά Ρωσικα ξέρω δεν είναι εκεί το πρόβλημα μου :P
Lol Blind Guardian??? Νόμιζα πως μονο τραγουδάνε αυτοί! :P
Mirror Mirror!!!!! r00x!!!
#12   aC3
aC3
  • 1.199 μηνύματα
  • GameCenter:_aC3_
Δημοσίευση 02/04/2009 - 19:59
Βασικά λογικά είναι το name κάποιου user...
Δεν χρειάζεσαι ρώσσικα, έχει και English Interface  ::)
#13   gabriella
gabriella
  • 577 μηνύματα
Δημοσίευση 21/04/2009 - 13:32
Καλημερα, χρονια πολλα !
Δεν μπορω να κανω copy the package κατι κανω λαθος. Μπορειτε να με βοηθησετε λιγο ?
Σας ευχαριστω!
#14   Alk1S
Alk1S
  • 1.098 μηνύματα
  • GameCenter:Alk1S
Δημοσίευση 09/11/2009 - 10:52
+1
Πολύ χρήσιμο και λειτουργικό.
#15   PaiN4ReaL
PaiN4ReaL
  • 62 μηνύματα
Δημοσίευση 03/02/2010 - 00:26
πολυ καλο αλλα μια ερωτηση ..
εμενα μ βρισκει το iphone .. αλλα βγαζει file error οταν παταω το get sources from cydia τι πρεπει να κανω ?
επισεις πως στο video διχνει στην οθονη του pc του τι διχνει το springboard του ?
Τελευταία επεξεργασία από: PaiN4ReaL, 03/02/2010 - 00:29
