ClamCase: All-In-One Keyboard, Case and Stand for iPad
12 μηνύματα σε αυτό το θέμα
Δημοσίευση 06/05/2010 - 11:24
Μία από τις καλύτερες θήκες που έχουμε δει για το iPad (προς το παρόν c0ncept,) είναι το ClamCase. Μία θήκη η οποία μεταμορφώνει το iPad σε... laptop!
http://www.youtube.com/watch?v=Sl5QWmhRYSw
ClamCase features:
BLUETOOTH® KEYBOARD
* The chiclet style Bluetooth® keyboard offers a tactical feedback allowing you to compose and type quickly.
* Your iPad® easily connects to ClamCases wireless Bluetooth® keyboard
* The only physical hardware keyboard solution with a case
* Manual power on and off button with blue LED indicator light and automatic power save mode.
* Connection to other HID compatible Bluetooth devices such as Sony Playstation 3®,
* Tivo® and HTPC (home theater PC) to give you the ultimate wireless keyboard experience.
* Bluetooth® technology enables the 30-pin dock connector to be free for charging, syncing and other hard wired functions.
360 DEGREE CASE
* The 360-degree torque hinges enable greater flexibility and fixed angles for featured modes of operation as the simple and sleek design of the ClamCase™ protects your iPad® from dents and dings.
* Made of high quality ABS plastic to ensure long lasting protection.
* Shields against falls and breakage, dust and dirt.
* ClamCase™ closed position guards against accidental openings and falls.
* Smooth yet grippy rubberized exterior texture of the 360 degree hinge provides a more user-friendly hold for confident handling.
POSITIONING STAND
* Designed to enhance the iPad® experience by providing a you-decide stand with an endless combination of positions to accommodate your desired tasks.
* Flip-back keyboard to expose the rubber hinge grip and enjoy your iPad® in tablet mode.
* Watch movies at the perfect angle with the uniquely designed ClamCase™ stand which can position into an infinite number of viewing angles.
* Manipulate the iPad® touch screen and use your favorite apps at just the right angle.
* The unique positioning of the ClamCase™ allows users the capability to display a digital picture frame slideshow in both portrait and landscape views.
#2   Billy4
Billy4
  • 24 μηνύματα
Δημοσίευση 06/05/2010 - 11:35
Καλη ιδέα και κατασκευή αλλά παίρνεις το iPad γιατί είναι iPad. Αλλιώς παίρνεις netbook και ησυχάζεις. Προσωπική μου γνώμη :rolleyes:
#3   geor92
geor92
  • 80 μηνύματα
Δημοσίευση 06/05/2010 - 13:35
Συμφωνώ Βασίλη αλλά έτσι μπορείς να έχεις και netbook και iPad σε ένα.. :rolleyes: Εννοώ σε σχέση με τις άλλες θήκες, κατά τη γνώμη μου, είναι πολύ καλύτερη. Και εξάλλου δε σου στερεί καμία από τις ήδη υπάρχουσες δυνατότητες του iPad.. :lol:
#4   stratos93
stratos93
  • 49 μηνύματα
Δημοσίευση 06/05/2010 - 18:06
Αυτο το πραμα δεν εχει λογο υπαρξης....!! γιατι σιγουρα φαινετε να κανει πανω απο 200 ευρο + το ipad 500+ ευρο... με αυτα τα λεφτα παιρνεις laptop 1000 φορες καλυτερο απο ipad...
γιαυτο ενα ipad ας το αφησουμε ipad.. και οχι laptop/notebook
#5   mike26
mike26
  • 369 μηνύματα
Δημοσίευση 06/05/2010 - 18:19
θα έλεγα τώρα τι παίρνεις αλλά έχε χάρη
#6   asdkostas
asdkostas
  • 433 μηνύματα
  • GameCenter:asdkostas
Δημοσίευση 06/05/2010 - 18:32
χαχαχα το μηλο τι ρατσα ειναι? :D
#7   chris
chris
  • 94 μηνύματα
Δημοσίευση 06/05/2010 - 21:41
Epic fail dude..
#8   Paris1986
Paris1986
  • 12.806 μηνύματα
  • Twitter:@par1scha
  • GameCenter:Par1s
Δημοσίευση 06/05/2010 - 22:17
Φοβερο...Εσκασα στο γελιο...
#9   mikexs
  • 5.698 μηνύματα
  • Twitter:@mikexst
Δημοσίευση 22/12/2010 - 10:26
Clamcase iPad Keyboard case/stand
Αγορα απο εδω > http://clamcase.com/.../clamcase.html#
119$ κανονικη τιμη και αν χρησιμοποιησετε αυτο το gift card > http://clamcase.com/...-gift-card.html η τιμη παει στα 99$
Full QWERTY Keyboard
14 Specialty Function Keys
4 Positions
Battery Life Indicator
Patented Hinge Technology
360º Rotation
Safe and Secure
Lightweight
Dependable Lithium Ion Battery
Stylish & Attractive
Made in the USA
http://www.youtube.com/watch?v=H4IbgCLzazw
Full QWERTY keyboard
Light and portable, CLAMCASE's™ chiclet keyboard with 14 function keys unlocks your iPad's® potential. Bluetooth connectivity allows you to email and message, update and organize, or search and surf with ease. Add iOS 4.2 multitasking and take your iPad® to the next level of functionality! CLAMCASE™ and iPad® are a productivity powerhouse!
Function Keys
When we set out to make the ultimate keyboard case for the iPad®, we made it a priority to include ALL the special keys. They're all here - HOME, LOCK, SEARCH, SLIDESHOW, VOLUME and MEDIA controls. With CLAMCASE™, dedicated CAPS LOCK LED, both shift keys and battery level indicator are standard - not optional.
Τελευταία επεξεργασία από: mikexs, 22/12/2010 - 10:32
#10   hercules
hercules
  • 6.248 μηνύματα
  • Tablet:iPad 4 +4G
Δημοσίευση 22/12/2010 - 11:03
mikexs νομιζω το καλυτερο απ'ολα απλα απαιχτο .
Τελευταία επεξεργασία από: hercules, 22/12/2010 - 11:03
#11   Iakovos80
Iakovos80
  • 329 μηνύματα
Δημοσίευση 22/12/2010 - 11:05
Ψηνομαι αγρια να τσιμπησω αυτη τη θηκη πληκτρολογιο...δε χρειαζεται μετα να παρεις macbook air :D :D
#12   mikexs
  • 5.698 μηνύματα
  • Twitter:@mikexst
Δημοσίευση 22/12/2010 - 16:42
Από το επίσημο site αυτή τη στιγμή στέλνουν μόνο εντός Αμερικής.
#13   grazzt
grazzt
  • 2 μηνύματα
Δημοσίευση 22/12/2010 - 19:17
Καλύτερα ένα macbook με τα ίδια λεφτά...
