Tethered Jailbreak 4.3
Δημοσίευση 15/03/2011 - 13:19
Creating Custom iOS 4.3 Firmware On Windows
Step 1: First up, download all the required tools and files to your Windows desktop:
Download and install iTunes 10.2.1 for Windows.
Download Sn0wbreeze 2.3 for Windows.
Download iOS 4.3 (Final) for iPhone, iPad or iPod touch.
Step 2: Start Sn0wbreeze, click the next “blue” colored arrow to proceed.
Step 3: Select the required firmware .ipsw file for your iOS device by clicking on the “Browse” button.
Step 4: Sn0wbreeze will now identify the selected IPSW file. Once done, click the next “blue” colored arrow to proceed.
Step 5: Now select the “Expert Mode”, followed by “Build IPSW” option to start creating your custom firmware.
Note: If your iPhone relies on a unlock, proceed only by selecting “Baseband Preservation Mode” option instead of “Expert Mode”.
Since building custom firmware may take some time, you can optionally play Pac-Man game to kill some time.
Step 6: Sn0wbreeze will greet you with the following “Done!” message when the custom firmware has been successfully created.
Step 7: Now follow the onscreen steps to enter DFU mode using Sn0wbreeze:
Hold Power and Home buttons for 10 seconds
Now release the Power button but continue holding the Home button for 10 more seconds
You device should now be in DFU mode
If you have followed the steps correctly, you will get the following message from Sn0wbreeze
Restore iOS 4.3 Custom Firmware Using iTunes
Step 8: Start iTunes, click on your iOS device icon from the sidebar in iTunes. Now press and hold Left “Shift” button on the keyboard and then click on “Restore” (Not “Update” or “Check for Update”) button in iTunes and then release this button.
This will make iTunes prompt you to select the location for your custom firmware 4.3 file. Select the required custom .ipsw file that you created above, and click on “Open”.
Step 9: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps. Be patient at this stage and don’t do anything silly. Just wait while iTunes installs the new firmware 4.3 on your iOS device. Your iOS device screen at this point will be showing a progress bar indicating installation progress. After the installation is done, your iOS device will be jailbroken on iOS 4.3.
Booting in Tethered Mode
Last but not the least, since there is no untethered jailbreak for iOS 4.3 yet, we will have to boot it into a tethered jailbroken state. To do this, we will make use of a utility on Windows named “iBooty” as shown in the steps below.
Step 10: Run iBooty for Windows and select your iOS device from the dropdown menu.
Note: iBooty is extracted to the desktop (iBooty-for-4.3) after running Sn0wbreeze 2.3.
Step 11: Now hit the “Start” button and follow the instructions on screen to enter your device in DFU mode:
Step 12: Once you are into DFU mode, iBooty will do its thing and after a short while, your iPhone, iPad or iPod touch will be booted in a jailbroken tethered mode !
Δημοσίευση 17/03/2011 - 14:21
γιατι το hotfile δεν το εχει
Δημοσίευση 17/03/2011 - 14:28
Μπορει να ανεβασει καποιος το install απο το Sn0wbreeze 2.3b1
Έχει βγεί το beta2.
http://hotfile.com/d...v2.3b2.zip.html
Δημοσίευση 17/03/2011 - 14:39
Βέβαια το snowbreeze 2.3 είναι ακόμα beta οπότε μέχρι λογικά θα έχει bugs . θα συνιστούσα λίγη υπομονή ακόμα για κάτι πιο stable
Δημοσίευση 17/03/2011 - 14:50
Δημοσίευση 17/03/2011 - 15:01
θελω να κανω jailbreak στο ipad
Δημοσίευση 17/03/2011 - 16:14
θα το δουλεψω λιγο και αν δω καποιο prob ενημερωνω!!!
ευχαριστω!
Δημοσίευση 17/03/2011 - 16:17
στην αρχικη οθονη του sn0wbreeze ποια πεδια εκανες (τικ) εννοω εκανες επιλογη
Επέλεξα expert και μετά επέλεξα Enable gestures menu και Install working MobileSubstrate. Προσοχή: ΟΧΙ "Activate"
Μήπως στο iPad έχει κι άλλες επιλογές από αυτές στο iPhone;
Δημοσίευση 17/03/2011 - 16:26
γιατι λογικα αυτο το εχει απο μονο του
Τελευταία επεξεργασία από: littlekid, 17/03/2011 - 16:26
Δημοσίευση 17/03/2011 - 16:48
αυτο που δειχνει για το ποσοστο μπαταριας ??
Όχι. Δε χρειάζεται
Τελευταία επεξεργασία από: gvala, 17/03/2011 - 16:49
Δημοσίευση 19/03/2011 - 16:15
είναι εύκολη η διαδικασία..?
Δημοσίευση 21/03/2011 - 17:07
δες εδωγια ipod touch 4 δουλεύει το jailbreak??
ετσι το εκανα εγω!!
Δημοσίευση 21/03/2011 - 17:23
Δεν μου περνούσε με τίποτα την custom 4.3 ,οπότε έκανα τη μα@@@@ια και έβαλα clean την 4.3 και μετα με τη βοήθεια του ireb που έχει το snowbreeze έβαλα τη custom 4.3 . Ολα καλά στο restore αλλα έλα που κολάει μετα σε recovery loop . Τι να βαζω dfu και να προσπαθώ με το recovery fix του tinyumbrella , τι με greenpoison ,ΤΊΠΟΤΑ .Εκεί κολλημένο σε recovery loop .
Κατι μου λέει οτι αν είχα new bootrom ή 4αρι θα είχε κάνει tethered boot κανονικά .
Τελικά το άφησα clean σε 4.3 και θα περιμένω το νέο JAILBRAKE tool . Κριμα και είχα πορωθεί λίγο με τα gestures και ήθελα να τα δοκιμάσω
Δημοσίευση 21/03/2011 - 18:44
Δημοσίευση 21/03/2011 - 19:49
και δεν ανιγει.μηπως πρεπει να κανω και το iBooty
