Αν έχετε jailbroken συσκευή, το iFile είναι μία από τις must-have εφαρμογές και η ενσωμάτωση του Gremlin framework θα σας χαροποιήσει ιδιαιτέρως.
Ακολουθεί το changelog με τις αλλαγές της τελευταίας αναβάθμισης:
Fixes
- Corrected broken links in Web Server index pages for files with special characters.
- Updated Chinese localizations.
- Loading of libstatusbar.dylib and SwipeToMoveCursor.dylib enabled.
- Romanian localization added.
- Celeste/Gremlin Integration
- Added support for sending files via Celeste (Bluetooth).
- Added support for adding songs to iPod Library using Gremlin for @cocoanutapps. This is possible in Attributes Editor and Music Player.
- Removed support for iBluenova for iOS 4.x and later
File Browser
- Added MD5 sum calculation for files in Attributes Editor.
- Initial directory content retrieval backgrounded.
- Added glass pane covering GUI while loading initial directory content.
- Replaced action button with clipboard button image (editing mode).
- Added support for up to eight tabs via new button in file browser toolbar.
- Added tab chooser using cover flow GUI. Allows adding and removing tabs.
- Added support for two-finger swipe gesture to allow swiping between tabs.
- Removed info button from file browser toolbar.
- Added support for long press on table to select, select all, deselect all, copy, cut, paste, link.
- Removed behavior that double tapping the table selected/deselected all files.
- Removed "Store on exit" option in preferences as it is obsolete in context of tabs.
- Added About iFile and Contact Developer fields.
- Implemented GUI Color setting (navigation bars and toolbars for selected viewers).
- Changed default icon theme to Leopard.
- Corrected cell formatting to avoid empty space in multi-line cells.
- Changed font size used in String Editor in Property List Editor (larger).
- Added support for extracting password encrypted zip files.
