iPad 2 Plus με Retina οθόνη μέχρι τέλος του 2011 (;)
Δημοσίευση 06/07/2011 - 22:36
Ο αναλυτής Craig Berger εκτιμά ότι η Apple αναμένεται να κυκλοφορήσει ένα ανανεωμένο iPad με υψηλότερη ανάλυση οθόνης, ένα iPad 2 Plus, όρο που εφηύρε ο ίδιος. Η συσκευή θα είναι απλώς μια ελαφρά αναβαθμισμένη έκδοση στο ήδη υπάρχον iPad 2 με ημερομηνία κυκλοφορίας μέχρι το τέλος του 2011
Εκτιμήσεις αναλυτών σπάνια αποδεικνύονται βάσιμες απλά έχει ενδιαφέρον το όνομα iPad 2 Plus (βλέπε Google+) και γι' αυτό το αναφέρουμε.
Δημοσίευση 06/07/2011 - 22:39
Δημοσίευση 06/07/2011 - 22:41
Δημοσίευση 06/07/2011 - 22:43
Δημοσίευση 16/08/2011 - 10:34
US-based tablet PC players Apple has recently canceled its iPad 3 supply schedule for the second half of 2011
Apple was originally set to launch its iPad 3 in the second half of 2011 with a supply volume of 1.5-2 million units in the third quarter and 5-6 million in the fourth quarter, but Apple’s supply chain partners have recently discovered that the related figures have all already been deleted, the sources pointed out.
The sources believe that the yield rate of the 9.7-inch panel that feature resolution of 2,048 by 1,536 may be the major reason of the supply delay since such panels are mainly supplied by Japan-based Sharp with a high price and Apple’s other supply partners Samsung Electronics and LG Display are both unable to reach a good yield. Since Apple is unable to control a certain level of supply volume, the iPad 3 is unlikely to be mass produced as scheduled, the sources added.
Sources from panel players also pointed out that the 9.7-inch panel with high resolution requires a much larger backlight source and a single edge light bar is hardly able to reach satisfaction levels. Due to iPad 3’s requirements over the physical thinness, rich color support and toughness will all conflict with the panel’s technology restrictions; therefore, this could cause a delay in the launch.
… και έτσι, μία ακόμα φτιαχτή ιστορία ολοκληρώνει τον κύκλο της.
Δημοσίευση 16/08/2011 - 10:47
Δημοσίευση 16/08/2011 - 10:53
Δεν θα το άντεχε και ο προϋπολογισμός μας πάντως. Είμαστε συνηθισμένοι σε ετήσιες δόσεις.
Δημοσίευση 16/08/2011 - 10:58
Δημοσίευση 16/08/2011 - 11:43
ελπίζω να μην ακολουθήσουν τον ίδιο δρόμο οι φήμες περί iphone 5 ... !
δυστυχώς το βλέπω να μας έρχεται με φόρα το πανηγυρικό άκυρο και για το 5 αρακι .....
Δημοσίευση 16/08/2011 - 15:45
Αναμένουμε πλέον φήμες για το 5άρι
Δημοσίευση 16/08/2011 - 16:43
Παρακαλώ να απαγορευτούν τα σχόλια αυτού του τύπου.δυστυχώς το βλέπω να μας έρχεται με φόρα το πανηγυρικό άκυρο και για το 5 αρακι .....
Πούλησα το λατρεμένο μου 4 και τώρα είμαι με ένα Sony Ericsson του κακού καιρού και περιμένω πώς και πως ένα νεο για το 5 και την ημερομηνία που θα το έχω στα χέρια μου και εσείς λέτε οτι θα φάμε άκυρο.
Απαράδεκτο να επέμβουν οι αντμινιστρατορς να σβηστουν τα απαράδεκτα ποστ
Δημοσίευση 16/08/2011 - 17:31
Όσον αφορά το iPhone 5 (ή 4S, ή όπως αλλιώς θέλετε), η καθυστέρηση του είναι σαφέστατα σκόπιμη, και κατά τη γνώμη μου οφείλεται στην καθυστερημένη κυκλοφορία του λευκού iPhone 4. Με το να μεταθέτει την κυκλοφορία του 5 μερικούς μήνες αργότερα, η Apple εκμεταλλεύεται τον επιπλέον χρόνο για να πουλήσει μερικές εκατοντάδες χιλιάδες λευκά iPhone 4 παραπάνω...
Δημοσίευση 16/08/2011 - 17:37
Είμαι στην ίδια μοίρα (λίγο καλητερα αφού βρήκα 1 3gs να κάνω την δουλειά μου) παει το 4αρι περιμένω πως και πως το 5!!!!Παρακαλώ να απαγορευτούν τα σχόλια αυτού του τύπου.
- Sent from my iPhone using Tapatalk
Δημοσίευση 16/08/2011 - 18:56
προσωπική άποψη καταθέσαμε μην τρελένεσαι.δεν είμαι το δεξί χέρι του Jobs ούτε έβγαλα ανακοίνωση.το απαράδεκτο θα ήταν να έβγαινε όντως νέο ipad απτο πουθενά σεπτέμβρη ή να μην βγεί το 5 αρι.Παρακαλώ να απαγορευτούν τα σχόλια αυτού του τύπου.
Δημοσίευση 16/08/2011 - 19:32
