![Αναρτημένη εικόνα](http://www.iphonehellas.gr/wp-content/uploads/2011/08/createpdf.jpg)
Creates PDF files that look exactly like the original using the same technology as Adobe Acrobat.
Consistent, high-fidelity PDF conversion independent of device or software. Uses Adobe’s online services to ensure there is no compromise on quality or performance. The service does not keep a copy of your original or the PDF document.
Creates PDF files that meet accessibility standards.
Preserves links, end notes, foot notes and creates bookmarks automatically in PDF files converted from Office documents
Preserves Transitions and converts Multi-media Content for Power Point files.
Convert email attachments or files stored in the cloud or any application by opening them within the Adobe CreatePDF application.
Hand over converted PDF files to other applications, including sending as email attachments with one touch
Το Adobe CreatePDF είναι διαθέσιμο στο App Store [link] στην τιμή των 7.99€
