![Φωτογραφία](http://www.iphonehellas.gr/forum/uploads/profile/photo-thumb-3.png?_r=1377707350)
iTunes 9 removes previous firmware IPSWs
Δημοσίευση 11/09/2009 - 11:09
Σύμφωνα το wikee.iphwn.org ερκετοί χρήστες έχουν παρατηρήσει ότι από την στιγμή που συνδέσουν την συσκευή τους, το iTunes 9 διαγράφει όλα τα παλαιά firmware .IPSW κρατώντας μόνο την τελευταία version:
iTunes 9 is a little more aggressive about firmware downgrades. People have noticed that the moment you connect a device, iTunes 9 will remove all but the most recent firmware IPSWs from its cache of firmwares. It will do this even if you aren't planning to update or restore. Previously, it had let them remain and you could Option-Restore (Mac) or Shift-Restore (Windows) to them.
This is currently only a minor inconvenience though because iTunes won't go outside of its Library to hunt down and remove these IPSWs (it could easily do this using Apple's Spotlight technology). But now is a good time to copy all your previous IPSWs out of the iTunes Library over to somewhere a bit more permanent. On a Mac, the caches are at ~/Library/iTunes/iPhone Software Updates and ~/Library/iTunes/iPod Software Updates. You'll still be able to Option- and Shift-Restore to them in their new locations.
If you've already connected a device to iTunes 9, your older IPSWs may still be in your Trash, so copy them from there.
Updates
1. Right now this is looking like a Mac-only behavior
2. The auto-removal may also depend on whether you've downloaded (even if you haven't installed) the 3.1 update
[Via wikee.iphwn.org]
Δημοσίευση 11/09/2009 - 12:32
![<_<](http://www.iphonehellas.gr/forum/public/style_emoticons/default/dry.gif)
![:P](http://www.iphonehellas.gr/forum/public/style_emoticons/default/tongue.gif)
Τελευταία επεξεργασία από: hector, 11/09/2009 - 12:32
Δημοσίευση 11/09/2009 - 12:36
οχι τιποτα αλλο βγαζει και λιγα....πωπω μου φαινεται πως η apple αυτη τη φορα εγινε πολυ επιθετικη με τα firmware του iphone και τα cracked apps και προσπαθει με οποιοδηποτε τροπο να τα εξαφανισει με την 3.1 και το itunes 9
.ισως να θελει περισσοτερο κερδος στο app store
Δημοσίευση 11/09/2009 - 13:12
![:rolleyes:](http://www.iphonehellas.gr/forum/public/style_emoticons/default/rolleyes.gif)
Δημοσίευση 12/09/2009 - 01:59
Δημοσίευση 12/09/2009 - 14:51
Δημοσίευση 12/09/2009 - 17:09
Αν βγάλω το iTunes 9 και βάλω το προηγούμενο, θα τα χάσει όλα (ρυθμίσεις, μουσική, video, apps κ.τ.λ.) και θα μου τα σβήσει από το iPhone ή
θα παίξει κανονικά;
Δημοσίευση 12/09/2009 - 18:03
Κι εγώ έβαλα το iTunes 9, αλλά δεν έχω συνδέσει ακόμα το iPhone.
θα παίξει κανονικά;
ωχ μάλον την πάτησες;;;;
Δημοσίευση 13/09/2009 - 02:54
Δημοσίευση 13/09/2009 - 14:45
Δημοσίευση 23/09/2009 - 01:26
να το βαλουμε η θα μας δημιουργησει κανενα προβλημα με το jailbrake?
Δημοσίευση 23/09/2009 - 12:17
Ρίξε μια ματιά εδώ :βγηκε το 9,0,1 itunes
